Stag EFi
    Stag EFi
    Check this out https://youtu.be/ZWkyxIPipRc
    That looks like Daddies. So lets chuck it in and give it a spin
      That's the Daddy.
        Originally posted by DJS View Post
        That's Stagdads latest masterpiece
          Want one! lets park outside his place till he drops us all one in.
            Fuel tank mods this weekend to finish off then a POR 15 sealer coating (not cheap but very tough)and I'm just waiting for a plug for my new idle control valve( trying a stepper motor this time)image.jpg
              Rumour is that he frequently drops one
                Steve.
                Assume you need an electrical plug, which valve are you using as I may have one.
                  It's a Delphi 150.2 femail plug, I have just arranged the seller of the valve to send me one John. RS do them but they have a minimum number for the metal connectors which you have to buy seperatly . This is the idle stepper I'm going to try. I'll be well happy if I can get it working as it's super light.image.jpg
                    You might be parked there for a while as it isn't finished yet!
                    I hope it all works well in the end as it is far better engineered than my cobbled together efi set up, but mine does deliver the ponies!
                    If Steve does read this it was me to whom you gave your extra air valve, if you can't get your stepper motor set up to work then PM me your address and I can post it back to you.
                      Oi
                        I have to say you guys have really come up with amazing kit, that engine sounds fantastic Steve, I Only wish I Had the time and resources to do the same.
                        I'm all for the modified Stag, keep it up!
                          [ATTACH=CONFIG]36218[/ATTACH]
                          Thanks Neil, I'd like to get the stepper working as in theory it should give a bit more control but I know this idle valve issue seems to be one of MS's tricky bits especially closed loop. I don't for one minute think it will make anything like your power outputs, I'd just be happy to get it running in the car with a bit more than standard, however Ive always got a head full of dreams for future upgrades some of them may be pinched from your findings
                            Such modesty!!!
                              Originally posted by mjheathcote View Post
                              Such modesty!!!
                              When I said I'd be happy, that would last about a week.
