Starter Motor Upgrade
    Three years ago I changed the starter motor for an upgraded 'motorsport' type, I think I got it from Cambridge Motorsports, but they are available elsewhere. I was prompted by poor starting on cold winter days. The change went well although it was a bit of pig to tighten the top bolt. The new starter cured the problem even though I never got round to putting in a substitute circuit to short out the ballast resistor (in the way the Stag original has).
    Now I have the engine out and I am reassembling it I checked the problem with the top bolt hole and found that the motor casting does not allow sufficient space for a socket to go on. I therefore removed the adaptor and cut off the offending section of the main casting, it has no structural reason for being there in this application.
    Anyone considering this modification should check the clearance before trying to install, it will save them time and scraped knuckles and ensure the motor is held by both flanges.
    Hope this might help someone.
    Barry
    sigpic Mk2 Sapphire 1976 mod, & Mk2 Sapphire 1974 4sp auto. (plus red/white wreck)
    I too have just changed a starter motor, but like for like. Yes, the top bolt had me scratching my head as well.
    Solution?
    I joined two 3/8 socket extentions, ( had to nip tp Halfords for the 2nd), then with socket attached, fed it behind exhaust manifold straight on to the bolt and rachet fits neatly at front of engine. Take front wheel off for bottom one.
    Two hours thinking about it, 15mins doing it
