Cylinder heads and manifold questions.
    I've had a great day - all the cylinder head studs and bolts came out perfectly and both heads are off. The LH head actually slid off the engine when I took out the last stud. A slight downer is that one of the inlet manifold bolts sheared off - but it has left about 1/2" of thread in the head to grab so it should come out with some persuasion. The LH inlet manifold bolts were barely tight, I could almost undo them without a spanner.
    A couple of questions:
    1. Should I use a spray-on jointing when fitting the new head gaskets?
    2. Is it necessary to use new bolts & studs in the heads? The studs that came out are clean, the bolts need a bit of attention from the wire brush.
    3. The exhaust manifolds were fitted without gaskets. Is this correct? I have new exhaust manifold gaskets but I don't understand why they'd have fitted the manifolds without them.
    TIA, Richard
    Hi Richard.
    When i fitted my new gaskets last year on the advice of Russ (kryton) I used wellseal on the gaskets. This worked a treat for me. I also fitted the new exhaust manifold gaskets.
    Rob.
      When i did mine getting on for 10000miles ago used a very thin smear of hylomar around the water galleries - no problems or leaks up to now.
      I re used the bolts following a good clean on the wire wheel and i opted for stainless studs. The bolt shanks were pitted in areas but not corroded enough to affect the strength of the bolts.
      I dont think the exhaust manifolds had gaskets originally. I didnt use gaskets in order to get more clearance between the tubular manifolds and steering shaft. Just a smear of silicone. It doesnt leak either!
      sigpic Stag Haulage, Flookburgh
      74 Stag Manual Triumph V8, Loads of other vintage scrap
        The exhaust gaskets were never fitted to the cast iron manifolds, but developed more for the fabricated tubular manifolds that need the tolerance the gaskets can give.
