Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74
When I woke up this morning .......blues -
Stag Owners Club Forum
Checked the water level which has always been on the expected low mark for ages rising up to the normal hot running mark when up to temperature but today when cold (very frosty) the level was at the normal hot running level and the top hose was pretty much 100% air.
the top of the rad was also down I have the dreaded air in the system )
Yesterday the temp gauge was normal on an 80 mile run
looked around and found the jubilee clip sealing the hose to the bottom of the overflow bottle had snapped ! I've fitted new one and will top up and bleed tomorrow .
I've also stared to collect bits for the fitment of a .................................................. ...a raised alternative water reservoir .
Any thoughts most welcome
If you want a relatively simple and cheap answer I'd recommend doing what I've done.
I've simply connected a Land Rover expansion tank to the existing expansion tank pipe and mounted it high on the inner wing. I've added a low level sensor and all's well - apart fom a slight leak into the vee.
The only slight concern about this is that the metal pipe goes an inch or two down into the rad and I could potentially get a slight air lock above that level however it's worked perfectly for some 10,000 miles.
Good luck. Cheers.
Yes agree, get one from a Discovery 1 and purchase also the bracket. Easy to fit. P1000881 compresed.jpg
Reason: add photo
Mario,
Just stopped in time shelling out £55 quid for a glorified fairy liquid bottle , as mine is cracked and leaking .
So a Disco 1 bottle will be ok ? They are about £20 on eBay .
From the photos I can see on eBay, there are two pipes. Presumably , one is the overflow and has nothing connected to it, and the other has the rad pipe connected to it ? You mention a bracket....what sort ??
Mario,
cheers
Mrs Hoskins, my mistake, its not out of a Disco but a 90 or 110. Landrover also had them in Range Rovers too so you should find a cheap good one. You plumb the bottom pipe to the radiator pipe going to the previous expansion tank and the top one (below the neck) acts as an over flow. Any other pipes should be blocked. You can see all three outlets in my photo above. Try and find one complete with bracket as it is easier to fit. Again see my photo for the bracket.
