Hi all
I have changed the EBC pads and found that the new ones had a very tight fit in the caliper slot.
The reason: the width should be 88 mm (see att. EBC data sheet) but they came with 89 mm! The old EBC ones are 88,5 mm and the very old asbestos pads are 88 mm. With 89 mm the pads are clamped in the slot and do not really open. Grind 1 mm off.
So better to check when you are going to fit new ones.
Klaus
Klaus
