Gent,s I am about to fit a new copper fuel pipe, but looking at the amount of bends that is in the old one this may be problematic. What would be the best way to bend the copper fuel pipe into the correct shape without creasing it ???
most if not all new brake pipes if copper or cunifer should be annealed and quite easy to form ,as previously stated good effective bending tools can be obtained cheaply but beware constant movement handling will start to work harden the pipe again .
Regards Moraystag
Bloody Hell Long time no hear from you on the Forum Mike - It's great to see you on here
Last year I completely 'repiped' a Stag and although it was a bit frustrating at times, it was all do-able. The hardest part was getting my head around which way to bend a pipe that seemed to bend in about 5 dimensions along its length .
Seriously though, the pipe benders that are widely available will do the job just fine. The only extra tool that I wish I'd had is a pipe straightener - they are not cheap at £30 or 40 but they will make your straight pipe runs look so much neater.
I don't recollect the exact diameter of the pipe so make sure you get the right one and you may well be able to find some tools a little cheaper than these.
Since decades I've never used those coiled sets due to exactly that what you described! I've been buying sets for other vehicles which use straight pipes, picking the one which has a suitable length, cutting it to size and swaging the end. That straightener opens up coiled sets as a possibility for the next resto! Thanks for the link.
I used a kit for mine however one length was short. My local auto shop flared the ends at my requested length. Only a few quid. I did all mine by hand and wouldn't want to invest in tools that I'm never going to use in 40 years.
For some reason I do not have access to quick replys or to start a new post, don,t know why it will not allow me to do so. Can someone direct this to a mediator and give me the access I used to have.
I will get this looked into.
Could you suggest what all I would need to remove in regards to exhaust sections drive shaft etc. I do not have much time before I have to leave for work abroad, so time is not on my side. Do you think I could put bends in the copper pipe, without the use of a pipe bender.
Also it seems that I cannot start a new thread for some reason it tells m,e I do not have access. Also, the site times out while I am still using it and I have to keep logging back in. I did not have this p[rob;em previously
Yes Neil, thats what I am thinking, and stuck underneath the car all day in the drive way does not fill me with enthusiasm especially as it,s blood freezing. Cheers
No worries Julian, am thinking of putting car into garage as I do not have time on my side. Could someone tell me if standard plumbers 8 mm copper pipe would be ok or does it have to be something else, ??
