I have been looking as to how to add a warning light without losing the original look of the dashboard.
I quite liked the idea of adding a LED to the centre of the warning light cluster but looking at the back of the cluster, it looked a touch daunting - I think that this was an earlier post on this forum.
I think that I’ve now found an alternative solution.
I have converted the red brake warning light activated by the PDWA switch so that instead of having a single bulb, it now has two 5mm LED bulbs fitted.
I fitted the two LEDs side by side into a suitable holder (I found some sort of plastic bottle cap with a spout) and this assembly is then pushed into the red lens cap.
One of the new LED bulbs is a self contained, flashing clear light bulb and the other one is a normal clear light bulb.
I have wired the flashing LED to my Kenlowe fan so that when the fan is in action, I see a flashing red light.
The normal LED has been wired in parallel to the original filament bulb connected to the PDWA so as to maintain the strange earth setup so that the oil light all works as normal.
I have left the original bulb in the void behind the dashboard with it's soldered connections well covered to prevent any electrical shorts.
The LEDs came from ebay (where else
) and cost about £4 including p&p – links to the two bulbs are below but I’m sure there are other suppliers but this one is in the UK and delivery is a couple of days (you end up with a spare 'normal' clear LED as they sell these in pairs).
I hope that this is of interest to some, it works for me but may not appeal to everyone.
Best regards
Paul
Best regards
Paul
