cam covers
    cam covers
    Had a look inside my cam covers yesterday,and they've had the wire gauze/filer cut out of them,what can i use, and where would i get it from
    thanks Dave
    Stainless steel scouring pad--Asda
      Bob
      thanks dave
        Rover flame traps in the breather line is an other option Dave
            you've lost me,what the h.... is a flame trap
            dave
              The gauze you refer to is a flame trap. On my project I have used rover ones as in the picture above rather than the in built one that the stag cover has. Just thought it may be easier than welding the cam cover as someone must have cut yours about.
                your quick on the typing tonight, just google flame trap,now know what your on about still don't under stand it,just as long as it works
                thanks dave
                  Mine are doing the same thing just that they are external/serviceable.
                    And the P6 flame trap is a better option in my opinion Dave, as it will just mean cutting a rubber hose to fit it - no major work required
                      I have a rebuilt engine that runs nicely, but I was getting a lot of oil coming out of the cam cover. I found that using a catch can filled with new gauze seems to condense the oil vapour, and when the can is raised above the cam cover it self-drains oil back into the cover rather than getting sucked into the engine. So I no longer lose any oil. I can only conclude that my cam cover breather must be clogged, and if it was restored maybe I would not need the catch can/extra flame trap.
                        I made my flame trap removable by converting the cover into a sliding mechanism.
