Hi. Trying to find the routing of the fuel pipe from the tank to underside of the car as my stag has had a new boot floor and I want to route it safely. Also what size hole do I need to drill to take the retaining clips ?
No need to drill any holes in the floor.
The fuel pipe runs from the pump down to the tank and then horizontally along the vertical wall closest to the passenger cell and exits the boot through the hole in the offside corner. You should see holes for the retaining clips, or more likely the stubs from the clips, around the level of the seam on the petrol tank.
