This is not an empirical response. I used Evans in my car with a reconditioned and higher capacity radiator and electric fan only. I never knew a worry free drive with the gauge always reading above half way and, in traffic or stationary, creeping up very quickly to frightening levels. Nothing I did to the thermostat on the fan switch made any difference - once the temperature had increased to the point where the fan was triggered it would ratchet higher and higher and the only way to break that cycle was to stop for half an hour. Such was my paranoia that I had the car tested for HGF twice in just over 2 years - both tests negative for HGF. This culminated in HGF about 2 years ago when I was stuck in a traffic jam at night and unable to switch off, just as I was about to order a fan the size of the ones used in cooling towers at power stations!
Enginuity did the HGF repair and checked the fan and electrics confirming there was more than enough airflow to do the job. They suggested going back to OE antifreeze mix with distilled water and I have had no problems since despite sitting in stationary traffic in July in Greenwich for four hours with the ambient temperature at 34 Celsius.
There might be other reasons for the HGF before the switch back to Bluecol but I will not be going back to Evans unless something changes. Don’t misunderstand me, I would say to each his own, but looking back, I feel I should never have consented to the coolant switch when the radiator was replaced. Before the old radiator failed, the car had not had problems according to the PO. I feel I made the classic error of changing several things at once, thus becoming unable to decide which change actually worked.
