Overheated Stag!
    Overheated Stag!
    Hi All
    Going to work this morning ... first time used the Stag for a few weeks (been using MGB instead ... how dare I!) Stuck behind a bin lorry ... Stag temp gauge showed just over 1/2 way. Thought OK, not bad given sitting in traffic. Got past lorry - but gauge kept on going up until it nearly hit the red and it started to pink. Thought s**t and pulled over ...
    Now Stag recovered to garage awaiting a diagnosis on the patient!
    Any ideas?
    Alan
    Assuminglast time you used it was OK, and there's planty of coolant in there, you may have a stuck thermostat.
    Also check your (viscous) enginefan is working.
      Divine retribution for using an inferior mode of transport and ignoring the Stag???
        had the same thing a few weeks ago turned out the new stat i had fitted would not open ran with out one for a short time no probs have now fitted anther stat again no probs
          Alan Hart wrote:
          Any ideas?
          Alan
          It's broken and sulking - the automotive equivalent of the cold bum and curlers routine the missus does when we ignore them.....
          Russ:dude:
            Hi, had the same happen on mine last yr, started the engine and in 2 mins the needle was in the red!, turned out to be the themostate and voltage
            stabiliser
              Hi
              Just got off the phone to the garage ... initial inspection suggests a core plug - there is water in vee apparently!
              Easy fix?
              Alan
                Russ:dude:
                Where does she put the curlers?!!!!
                  In her hair - where else?:shock:
                  It's the female equivalent of the anti-tank obstacles we put on the beaches in WW2, but infinitely more portable and effective
                  Russ:dude:
                    Alan Hart wrote:
                    Hi
                    Easy fix?
                    Alan
                    More likely to be inlet manifold gaskets than core plugs, but my psychic powers are down today so cannot be more precise......:dude::dude:
                    Russ:dude:
                      Hi All
                      Just got off the phone to the garage. They have cleaned the engine and it isn;t the core plug(s) ... ummm ... a specialist engine builder has said it could be a cracked head which sounds bad (and probably expensive!).
                      My garage is getting another opinion on Monday. But I've suggested that I take to a specialist Stag garage - so my question is can anyone recommend one in my area - either Buckinghamshire or North - North/West London, Berkshire ... that sort of region?
                      I'm very keen to get this sorted ASAP as I have just sold my MGB GT ... so I could use the Stag!
                      Alan
                        Enginuity in Acton?
                          If there's water in the V it could bewater pump seal failure a core plug, or as Kryten says inlet manifold gaskets. Problem is these could be a symptom of the overheating not the original cause.
                          Does it immediately overheat when you start it up and run it up to temperature or does it take awhile? and how much water is leaking?
                          <edit> for Red Dwarf spelling!
                            Hi
                            Of course ... heard good things and didn't realise Acton is just off the North Circular - that's a Northerner for you!
                            Alan
                              Kevin Garrod wrote:
                              Enginuity in Acton?
                              After talking to the guys there on the Power Challenge day i would agree, other faily close specialist would be N&P Motors on the Bath Road near Heathrow
