Sorry if this is an old topic but has anyone experience of fitting a more modern falling rate power steering pump to overcome the constant rate lightness of Stag racks?
Alternative power steering pumps
probably easier to buy an MX5
#joking
Sort of, surely half the charm of driving an older car especially a Staaag is the feel of it. I it steers like a Lexus and Stops like a New Merc SL bits of its soul are being robbed away.
Says the bloke with Rover Tomcat seats, modern ICE, header tank and lecky ignition lol
I fitted a recon rack that I bought from HRS a decade ago, it had something special done inside it and does feel nice. Still light but not overly so. Tony Hart still posts on here he may be able to fill us in on wizardry that may or may not have taken place.
RichardStags and Range Rover Classics - I must be a loony
Originally posted by mike@thenook View PostMy rack is as (traditionally) light at all, very good feel to it and in fact it's no as light as my 03 Freelanders steering. Think I got my rack from Paddocks about 10 years ago...
You can make mods to the valves so that less assistance is given through the hydraulics.
The original rack was completely different and very light but had done a lot of miles.
Pete
An easy adjustment is to undo the large nut on the back of P/Steer pump (high pressure). Retrieve the internal piston and on the end of it is several shim washers, remove one or more, reassemble and test drive, I took both shims out of mine and it did increase the feel, not as much as I'd like but better.
Cheers, Ian A.
Originally posted by stag8manod View PostAn easy adjustment is to undo the large nut on the back of P/Steer pump (high pressure). Retrieve the internal piston and on the end of it is several shim washers, remove one or more, reassemble and test drive, I took both shims out of mine and it did increase the feel, not as much as I'd like but better.
Cheers, Ian A.
I've an unfinished project of replacing the original pump with a Mercedes A class electric pump. This fits nice and neat where the original water expansion bottle was.
Popular mod with engine swops when difficult to fit a belt driven pump.
I have no engine swop, but hoping for better feel using one.
The other reason that with the alternator being now on the upper nearside due to my front exiting tubular exhaust manifolds, I could mount an air con compressor in place of the alternator...another project!!Mike.
I used to think that all stags had over-assisted steering, but I have found that they do not need to be that way, and that their is quite a variation of racks in service. Mine now is just about right, and so is the spare that I have. It is always worth trying out a different rack to find a good one. I think the design changed at least once, but I dont know if they are marked differently for identification.
Originally posted by 72BLUE View PostI remember reading a while back that the Triumph 2000 rack looks the same as the Stag rack, but they are 'weighted' differently?
I've had different PAS racks in the Stag and the various big saloons I've had and they have varied in assistance. I did read somewhere that as it ages, a rack provides more assistance due to the wearing of the various 'orifices' which are used to reduce the fluid flow and hence increase the assistance. I don't know if this is true but it does make sense. Now, whether this is in the rack or the pump is anyone's guess!
Mike.Mine since 1987. Finished a 20+ year rebuild in 2012. One of many Triumphs and a 1949 LandRover!
I know of someone who has fitted epas from a corsa to a stag.
No reports yet though.
FWIW, I just got a low mileage 2005 car with epas, the straight ahead condition is really awful / horrible. (its probably a valeo system...... c**p)
The manual has 35 pages of fault finding for the epas system alone hmmm.
I've now come across a power steering pressure adjuster made in America and sold by Real Steel over here. The make is Heidt who seem to me quite established on the muscle car scene but not yet found any independent reviews. It is a simple design that allows the pressure to be adjusted by diverting "excess" pressure back into the low pressure circuit depending on how you set the adjuster within the range. Not cheap at over £100 plus new hoses/ additional hoses though.
The Honda engined V6 Rover 800 had a valve fitted to the gearbox that ran off the diff speedo drive worm. This valve reduced PAS hydraulic pressure according to road speed, to no assistance by 25mph, and was directly linked into the PAS hydraulic lines.
Will see if I can find my books that describe the actual mechanism by which this happened - might even be adaptable to our more primitive PAS system.
