I'm trying to stop an oil leak around the oil transfer housing area.i've done the transfer housing and that has slowed it down to 2 drops left when i park up .cam covers are ok .Do the oil pumps normaly give problems with leaking?
I believe the oil pump is sealed by an O ring and can be asource of a leak,it is fairly easy to replace, once you have removed your downpipe of course. I blamed mine for ages then I tightened up the screws on the cam cover - no more leaks! The only leak I get from mine now is the dif which is very small and won't be rectified for some time.
