Power steering bleeding
    Bristol Hose are replacing my hose rubber pipes and am thinking ahead to refilling with fluid. 'Being a biker and all that' I've never even seen a PAS pump etc before. Am I ok to just reconnect the pipes/pump, re-fill with fluid and then turn from lock to lock like I saw on the telly....?
    Oh, and anything in particular not mentioned in the Haynes Manual I need to take care of when refilling with coolant please?
    Sorry for all the numpty questions!
    Mark
    To bleed the PAS you just need to turn the wheel lock to lock a few times. That seems to purge the air OK!
      Jack the front end up for both jobs.
      It'll take the load off the steering column UJ's and will raise the radiator/filler level to help purge any air bubbles.
        Thanks both
