Warning: Undefined array key 13972 in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/user.php on line 1
Warning: Undefined array key "online" in phar://.../vb/vb.phar/library/content.php on line 2
Warning: Trying to access array offset on value of type bool in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "reputationimg" in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Trying to access array offset on value of type null in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 72
Warning: Undefined array key "reputationimg" in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Trying to access array offset on value of type null in /home/socforum/public_html/forum/includes/vb5/template.php(404) : eval()'d code on line 77
Warning: Undefined array key "birthday_search" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "joindate" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "posts" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "privacy_options" in phar://.../vb/vb.phar/api/user.php on line 1
Warning: Undefined array key "userid" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Undefined array key "lastactivity" in phar://.../vb/vb.phar/library/user.php on line 2
Warning: Trying to access array offset on value of type bool in .../vb5/route/profile.php on line 74
Tightening Up the Inlet Manifold Bolts -
Stag Owners Club Forum
Last summer I replaced the inlet manifold gaskets as it was weeping a little water. The operation had no effect at all as it is still weeping a little - very little in fact but it's annoying. As I have recently bought a a refurbished set of carbs I will take the opportunity to tighten up the bolts again hoping for better results. My question is: in the case that a bolt strips the thread, would it be advisable to purchase a similar bolt but with more 'bite' in its thread to avoid helicoiling?
If one strips, helicoil the lot. only way to fix the problem once and for all. If you drive in an oversized bolt, you may lose the ability to helicoil later.
Plenty of threads here on this subject, complete with the recommended drill/helicoil/bolt sizes. Search is your friend!
Do remember some of the bolt holes at the bottom are very close to waterways so tread carefully with long bolts, I shouldn't think it would take much to punch through the alloy into the waterway.
Especially if you have fitted a ..................can't bring myself to mention it. But anyhow, mine does exactly that.
Yes it has an unmentionable container high up.
Chris, it doesn't have the waterpump any more as it's been replaced with an electric one. I'll have a look with an endoscope to see if there are any leaks before I take off the carbs though.
I didnt realise you had the EWP Mario. In that case I guess the inlet manifold must be the culprit. I need to check mine soon as I am losing water invisibly. I just hope the PO used the correct method of alignment when fitting the heads.
When I have Helicoiled into aluminium,I've never needed to drill first.This was as per my helicoil instructions, as I thought at first I would need an angled drill...you don't.
Ken.
You said you replaced the inlet manifold gaskets and its still leaking,did you check that the manifold was sitting up against the heads squarely ( i mean no gaps at the top or bottom )some times you may have to have the inlet manifold skimmed
When I fitted my inlet manifold and heads after the last re-build I did up the bolts on the inlet manifold before torquing down the head studs.
This presumes that you will be undoing the heads or at least one before you try to sort the inlet manifold leaks as doing it with the heads in place is very difficult, not recommended and likely to only last a short while if at all.
[QUOTE=mike@thenook;350975]When I fitted my inlet manifold and heads after the last re-build I did up the bolts on the inlet manifold before torquing down the head studs.
Mike[/QUOTE
I read somewhere that Triumph actually suggested to loosen one head before torquing up the manifold - which is a big No No I think. I would have thought that new gaskets and gasket sealer would take up any differences between the mating surfaces. I am following the Rimmer video which is in the Technical Section for the process
