Hi All,
My jackshaft has seized and because the front of the engine will need to be stripped down to find out what has caused it (hopefully the water pump), I am considering carrying out some other works at the same time. The work will be carried out by my local garage. So this is what I am considering having done:
1 Replace the radiator:
Should I consider a standard rad, new or reconditioned or upgraded? The current rad seems to be the thicker, uprated one and is extremely close to the fan. I have read that the standard rad is actually more efficient than the uprated one due to allowing more air to pass through it.
2 Install an electric fan:
Should I do away with the viscous fan and if I do, do you remove just the blades or the viscous coupling as well? If you remove the coupling, is there any items that need to be altered, eg. the coupling retaining bolt, does it need to be shorter or can it be left off?
Which side of the rad does the fan go, how does it fix to the car and where does the thermostic control go?
3 Replace the timing chains:
Should I replace them (they do not rattle). They were replaced in 1991 at 72000 miles, now done 86000 miles. If I change them should I fit standard or German, should I replace all the sprockets?
Obviously when we get the jackshaft and pump out we will know what we are facing and this may put paid to any thoughts of modifications. Anyway, thanks in advance for any help.
Dave.
Dave.
