Hi all,
After 3 1/2 years off the road and a full nut & bolt rebuild I was looking forward to firing the old girl up again last weekend, seems she has other ideas!
I've got a spark at all 8 plugs, fuel going into the inlet manifold, starter kicking in, a good battery and good compression on all cylinders.
When I turn the key she desperately wants to start and run but when I let the key return she dies. I've tried using East Start and the fuel is fresh.
There's no points as Lumenition is fitted, I'm not running a ballast resistor.
I'm thinking the likely culprit is in the ignition or LT / HT circuit but have no idea where to start to check things over. I did remove the remains of a simple immobiliser system when I put things back together - used to have 3 wires running to a little black box, 1 from the coil, another to the purple Lumenition wire and a 3rd wire and to an earth. I've now taken the purple Luminition wire directly to the negative side of the coil. Problem is I have no idea how the coil would have been wired up initially, it would appear that there originally may have been 2? wires running to the coil, both look brown & cream in colour and seem to have been connected to each other, not sure if this is to do with Rev Counter which I have been led to believe forms a part of the ignition circuit.
Any thoughts as to where the problem might lie?
Much appreciated.
Iain.
Much appreciated.
Iain.
