Over the past year or so I've been watching the market on both LED Fluorescent tubes and more regular style LED bulbs. It takes a little research to get the right items for performance and ease of fit at the best price.
I did see a a thread on here and read it once or twice but stuck with doing my own fact finding. I'm just about to complete these conversions and now I can share the experience to hopefully save anyone else time and money.
Bulbs
The first good 'find' was Toolstation, who have regular Bayonet or Eddison Screw type LED 240V bulb replacements at a mere £10 a pack of 5 - £2.00 each, and delivered!
After testing I bought rather a lot to replace every bulb in the House and Workshops. They are said to equate to an incandescent output of around 80W, but in my opinion they equate to more like an 100W bulb. Direct conversion is not so easy as they are often given a rating in Lumens, not Watts, and the Lumens per Watt consumed can vary with design. The bulbs are a direct replacement, no other changes are required. These are not suitable for dimming but that does not bother me at all.
Fluorescent Tube Replacements.
After a lot of searching and trying one or two types out in the house, I settled on these to replace my 5ft tubes (I only ever fit 5ft's to avoid the expense of other sizes);
Amazon UK
'10 pcs Auralum® 22W 5ft(150cm) T8 Fluorescent Light LED Tube Glass White(6000-6500K) 2420lm SMD2835*120LED Replaces Neon Tubes Energy Saving Daylight Lamp with LED Starters-Milky Shell' by Auralum www.amazon.co.uk
Technical Specifications: - Length:150CM - Input Voltage: 22W - Lumens: 2420LM - Color Temperature: About 6000-6500K
These come with the conversion 'Starter' included in the price - around £10.70 or so each, again with free delivery! They are a little bit brighter than the FL tubes they replace, but some of that can be down to dirt on the old ones, but still...
The extra work of converting the FL unit internal wiring is avoided by the starter replacement, although those with High Frequency FL units may need a different type of tube and more research.
For me, there is far less guilt and cost concern when switching on 20 tubes at a time as they now only use 22W apiece, and the light is instantly bright, none of that miserable start-up pallor from the Energy Saving bulbs and old style FL tubes of yesterday.
So, anyone wanting to use their lights more instead of (like me) avoiding turning them on can now have part of their life brigthened, or simply save quite a lot of money, or both.
Fill your Boots!
Bulbs
Amazon UK
Fill your Boots!
