seat belt buckle
    seat belt buckle
    ive been looking on paddocks site,they did sell the seat belt buckle,but are out of stock,the trim on the outside of mine has broke,any ideas how to repair it,the buckle still works
    thanks Dave
    Dave,
    I thought you were having yours re webbed?
      Dave,
      Jeff
      I will be getting the belts rewebbed,its ive just noticed the buckle ( the part down on the floor ) has a out side rim broke, any ideas how to repair
        Got pics Dave?
          One of mine has been wrapped in strips of black universal repair material (aka gaffer tape) since I bought the car and found the plastic trim under the seat.
          "If it doesn't move and it should - WD40. If it moves and it shouldn't - gaffer tape".
          Chris
          74 manual o/d, white with shadow blue. Datsun axles, Sierra HT.
            any one got any ideas how to repair this IMG_0179.jpg the buckle still works its only the outside trim broke
            thanks Dave
              Chris
              chris
              i think to much of the trim is missing to wrap gaffer tape
              thanks dave
                What's it made of Dave?
                  Jeff
                  its made of plastic,looking closely at it there's a screw on the under side,so i think you can remove the hole trim,im going to try fibreglass to build up what's missing,if i add a little bit of white paint to the fibreglass mix,will it turn it white ?
                  dave
                    Have you called all the Stag breakers advertising in the Mag. ? Although l have heard that some refuse to sell used seatbelt bits so tell them you need 1 to experiment on.......
                      That's what I was going to suggest Dave. Never added paint so not sure, could get a bad reactions???
                      I think filler would be too brittle and easy to damage plus getting it to adhere whereas fibreglass will be stronger then finish off with filler?
                      Jeff.
                        Hi Dave,
                        Mine broke in much the same way. I got a replacement from Wins. They might be worth trying.
