Diff seals and bearings
    My diff is leaking oil from the front seal.
    The breather is clear.
    When I drop the diff assembly I plan to replace the seal and bearing in the diff extension and the seal on the front of the diff.
    Advice on previous threads is to replace the bearing in the diff nose as oil will have flushed the grease from the original bearing.
    My diff is a later type with a collapsible spacer washer. Can this washer be replaced? Should it be replaced?
    Having read the ROM and Haynes manual I admit to being still confused.
    Any advice would be most welcome.
    steve
    you said the oil is leaking from the front of your diff,once you have taken the front diff extension off, to replace the bearing inside,you should be able to get to the oil seal at the front of the diff,you don't need to touch the collapsible spacer
    dave
      Hi Steve,
      There is only a bearing in the diff extension, circled in picture
      The Diff seal can be replaced without disturbing the collapsable spacer as the seal can be prised out and replaced quite easily.
      There is a excellent modification which I carried out this mod courtesy of Klaus Shuleur which involves drilling a drain thole to prevent any oil that does leak should not wash any lubrication away, it can be found at http://socforum.com/forum/showthread.php?27832-Diff-extension-bearing-a-modification&highlight=diff+drain
      Diff Ext Drain.jpgHope this helps.
      Nigel
        If you are going that deep into it, might be worth fitting a reinforced diff extension housing f you don't already have one.
          Just had mine done at faversham classics done a great job. All done and up and running again now. First class service��
            Thanks for the responses and thanks to Nigel for the pictures.
            I think I've built this job up in my mind to be complicated but now feel more confident.
            Best wishes
