Lower springs
    Lower springs
    Can anyone out there help me in my moment of mind numbness... I'm looking at lowering the front end of my Stag by 1" by fitting reduced height springs, as I type I'm starting to realise how silly a question this is, but can I retain the original shocks, or do I have to fit reduced height shocks as well? Are there any other items that would need replacing at the same time?
    Yours unintelligently
    Same shocks. might be a good idea to replace the spring insulators as well at the same time I used pollybush
      Suggest you get the tracking checked after - disturbing stuff usually alters the front wheel alignment
        Are you building a dragster then John...?
          Yes, I'm curious too. Why only the front?
            Rover?
              Originally posted by Paul Roberts View Post
              Rover?
              Down boy! Woof! Woof!
                Thanks for the advice folks, polybush insulators and tracking are now on my list!!
                I'm not making a dragster, and she's an original TV8 engine dream
                She looks too high on the front arches, hence lowering the front, I have thought about dropping the rear as well but lowering by the same amount wouldn't solve the front arch problem, and I don't want to drop the front by 2 inches to allow the rear to go down by 1 inch (1 and 2 inch drops are all I've found online so I'd welcome any other suggestions on how to do this)
                Thanks again for your help
