Hi all, is it safe to drive the auto without the kick-down cable attached? Just cant seem to get the adjustment right. Have down every thread on the cable. Holds 2nd to long for my driving preferences. It drives quite nice without the cable attached. I know I will not be able to kick down but that doesn't concern me. Could it do any damage to the box? Maybe the cable has stretched? Cheers Mark
Kick-down
Originally posted by markmark2 View PostHi all, is it safe to drive the auto without the kick-down cable attached? Just cant seem to get the adjustment right. Have down every thread on the cable. Holds 2nd to long for my driving preferences. It drives quite nice without the cable attached. I know I will not be able to kick down but that doesn't concern me. Could it do any damage to the box? Maybe the cable has stretched? Cheers Mark
Ignore the last post, no harm will be caused to your Gearbox with the the Kickdown disconnected...........Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Assuming you have a BW box then if the box changes fine with the cable disconnected, I would suggest it is too tight if it holds onto 2nd too long with it connected. Re-connect it, back off the adjustment fully, and try again. It should shift up into 3rd around 25mph on a light throttle.Dave
Originally posted by milothedog View PostIgnore the last post, no harm will be caused to your Gearbox with the the Kickdown disconnected...........
not a qualified mechanic myself but even I know having no kick down cable will just do exactly that, no kick down to change down gear, no harm whatsoever, just use gearshift.I only do what the voices in my wife’s head tell me to do!
Originally posted by DJT View PostAssuming you have a BW box then if the box changes fine with the cable disconnected, I would suggest it is too tight if it holds onto 2nd too long with it connected. Re-connect it, back off the adjustment fully, and try again. It should shift up into 3rd around 25mph on a light throttle.
Slacken it right off Mark, so that the outer cable is tight up to the securing bracket. Most of the thread will be above the bracket and you will have less inner cable showing. There may be a small collar crimped to the inner cable. If there is, and the cable has been adjusted correctly before this was crimped, then there should be a small gap between the crimp and the outer cable. If no collar, or it is loose, then ignore it and find the adjustment that suits you.Dave
Originally posted by DJT View PostSlacken it right off Mark, so that the outer cable is tight up to the securing bracket. Most of the thread will be above the bracket and you will have less inner cable showing. There may be a small collar crimped to the inner cable. If there is, and the cable has been adjusted correctly before this was crimped, then there should be a small gap between the crimp and the outer cable. If no collar, or it is loose, then ignore it and find the adjustment that suits you.
If you find at maximum adjustment (slackening) that it still holds on to gears before changing up then carefully snip of the crimp to allow a little more slack, this was common practice when I worked in a main dealers (albeit Rootes) to get a little more life from a tired gearbox.
Ian.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by milothedog View PostIf you find at maximum adjustment (slackening) that it still holds on to gears before changing up then carefully snip of the crimp to allow a little more slack, this was common practice when I worked in a main dealers (albeit Rootes) to get a little more life from a tired gearbox.
Originally posted by markmark2 View PostHi Ian, sorry there isnt any crimp to cut off. MarkYou shouldn't really get any kickdown until the throttle is nearly fully depressed.
Don't confuse it with a modern car, its a very basic hydraulic operated system dependent on road speed and throttle position..Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Originally posted by milothedog View PostThen just set it as slack as you need to until your happy with how it performsYou shouldn't really get any kickdown until the throttle is nearly fully depressed.
Don't confuse it with a modern car, its a very basic hydraulic operated system dependent on road speed and throttle position..thanks
Mark, just adjust it until you find the happy medium. if it changes up and down reasonably smoothly then that's fine. Like I said you will cause no harm to the gear box by playing around with the kickdown adjustment.Wise men ignore the advice of fools, but fools ignore the advice of wise men sigpic
Mark, if you get really stuck there is an excellent auto gearbox shop in Hornchurch Road on the corner of Hylands Way. They have a workshop at the back. Couple of old boys been there for years and love classic cars and specialise in BW boxes. Had mine serviced there and new filter fitted and new fluid. they adjusted everything and the car has driven perfectly ever since. Cost me around £90. I couldn't believe the speed of the stag the first time it kicked down after they had fettled it.
Regards, Steve
