Well summers here so work continuess
    The very very last final bit of welding
    Ground off
    Thin layer of metal loaded filler to get the shape right
    Been doing some of the paint prep work too
    Thought i'd check the standard of my prep as its been 25 odd years since I painted a car, feels good to be finally shooting some primer on
      shot some primer to check where I had replaced the rear arch too, I have a low spot so I avoided spraying that until its been skimmed in but the arch prep looks pretty good to me and it is still to be dry flatted (high build primer).
        Well done Ian, keep at it, looking good
          Thanks Andrew. I can't believe it's been 6 years since I started welding it! But I don't get a lot of time and my garage you have seen and it isn't big enough to work in. So progress was always going to be slow. Given a good summer getting it painted this year should be possible. ��
            As Andrew said well done, wish I had them skills, what colour are you going for?
              Thanks , I didn't have those skills 6 years ago, well the welding anyway.
              Primer shade 19
                looks like you were lucky on the boot lid,not as much rust as mine,nice work,bet your be pleased when its all done
                dave
                  Awesome Ian, wish I could do some welding! Once resprayed you'll see the light. Will you be doing that in your garage too?Keep it up, great rewarding job.
                  Good luck,
                    dave
                    Boot lid was brand new in 1989 and its been mostly garaged since then. I'll be really happy when itrs finished. Haven't driven it since 2001!
                      Good luck,
                      Garage is only just wide enough for me to get out of the Stag on the driver's side when it's really close to the wall on the passenger side. No room to spray in there. I have bought 2 3m x 4 m gazebos with sides. A large box fan which will be blowing in through a cooker hood filter and I'll cut a section out of the opposite end fit a an activated charcoal cooker hood filter in the hole. That will be my spray booth
                        Love the transportable spray booth. Maybe you could hire it out when you've finished.
                          Let's see what the neighbours think of it first
                            Well done Ian
                            keep eps up the good work
                            Cheers Glenn
                              Thanks Glenn, certainly aiming to get it done this summer
