Hi all
I need to replace the bush at the top of the steering column as a number of the ball bearings have escaped and the steering wheel has a lot of play in it. In my naivety, it looks like I should be able to simply remove the top end of the outer column, but the question is what to do with the steering column lock/ignition switch. Would I be able to leave it in situ and simply insert the keys to make sure the lock is in the 'open' position and withdraw the assembly from the top of the column, or is it necessary to remove the lock/switch completely?
I'm guessing the answer may be 'you have to do it the hard way and remove the lock/switch', but just thought I'd ask!
Gord
Gord
