oil in the 'v'?
    oil in the 'v'?
    Hi all
    I was tinkering about earlier with the kick down cable and carb idle speed to see if I could improve the auto gearbox clunking, when I noticed a small amount of oil in the v at the back of the engine near the bulkhead. it had burnt off by the time I came back from a short run, but cannot quite see where it's coming from. Is there a usual place to check for this, or might it be head gasket? The oil level appears to have stayed about right, but I am worried a little now!
    cheers
    Hi kevin.
    Could be oil or water or a mix of both!! If its gone after a run more likly to be water. Could be from a number of places, inlet manifold gaskets or the water pump. If the car hasnt been used for a while, it could be the seal on the water pump, dont worry too much about it as long as it dosnt get worse it will probably seal with use, but if the leak worsens, investigage further as it could be failing, or as i said before the inlet manifoldgasgets failing. Dont get too paranoid about it just yet, lots of stags are a bit incontinent at some point, just moniter for now.
    Good luck
      Cheers Dave
      that's good advice - I hope to be the car into a local specialist to be fettled in the next few weeks, so I'll get them to take a look and add it to the (ever increasing!) list of things to sort.
      Kevin
        Who is the local specialist, can't say I know of one.
          If its water put some K Seal in the radiator and have a good run, appears t have cured mine, but I still occasionally get fuel overflow in the V.
          Nigel
            It ain't me Bob
              My cat has never fixed my car or wears glasses, did he serve a full apprenttice.
                Yes - he fits cat-alytic converters
                I'll get me coat
                  Hi Kevin,
                  My mean green machine had 'moisture' in the V. I think it was a mixture of oil from the gasket to the cam covers (now fixed), and leaking coolant. On investigation,I discovered the slightest of leaks coming from the heater return pipe where it joined the top pipe into the heater matrix. I tried adding a second jubilee clip but this failed to stop the constant weeping onto the V. I say constant as this only happened after running the car. On removal of the heater return pipe it was found to be corroded where it joined the rubber hose. It was replaced with a new stainless steel pipe since when no more wet V or loss of coolant. Suggest you check for the same.
                  Best wishes
                  Nigel
                    Hi bob
                    I was going to use Tim Collins at The Vehicle Restoration Co in Middleton on Sea near Bognor? Do you know them?
                      Originally posted by RobinLegin View Post
                      Hi Kevin,
                      Best wishes
                      Nigel
                      Thanks Nigel
                      That's useful info to check
                        Originally posted by kevin p View Post
                        Hi bob
                        Sorry but can't see the the budget going far
                          Hi bob
                          Hi Kevin, I've heard of them but honestly do not know of anybody that has used them. Wouldn't say they were a Stag specialist by any means. The offer is still there if you want a second opinion, let me know.
                          Bob
                            Hi Kevin. Get Bob to look at it first, he will give you an honest opinion of what is required. He certainly knows his onions (and stags!)
                              My cat has a lisp & he cannot sthpell
