When to change your plugs?
    Despite some recent problems with my Alternator, Battery, and PAS bracket bolts, when my engine is running - it is running really well. It sounds right and all gauges indicate everything is working as it should.
    When the car wouldn't start a few weeks ago (it was a fuel probem since resolved), l did remove a couple of plugs to check I was getting a spark O.K., and one of the one's I removed looked fine and the other a little "sooty" (if that is the right word).
    When I recently ordered a new fuel pipe and filter from Paddocks, I also ordered a set of plugs as it seems years and years ago that I last changed them, but I remember when I did I had to helicoil a couple of the spark plug holes as the threads stripped.
    My question is this, as the car is running well should I leave changing the plugs till later, or should I do it now before I have any problems in that area? What is an indicator (if there is one) that it's time to change the plugs?
    Terry
    Terry
    Don't fix what isn't broken
      That's kind of answer (reply) I like. So it's back to the Pool tomorrow instead of working on the car -
      after all it must be least 100 degrees Farenheit at the moment out here.
