kickdown cable
    kickdown cable
    :dude:hi guys , have anyone done a kick down cable adjustment, i have just replaced the cable but not sure on how to adjust, thanks paul
    Adjust the cable until the crimped stop is 1.5mm from the end of the cable collar. If the upshifts occur at the right speeds all is OK. If it upshifts too early, increase the effective length of the outer cable, and vice versa if upshift is too early.
      Officially using an oil pressure gauge on the 'box tapping and set at about 60psi atidle.
      Unoffically as Chris says and roadtest to be in 3rd on very light throttle at about 22mph on a flat road.
      Russ:dude:
