Door closing
    Door closing
    I spent more time than I should have trying to fix my door,to get it to close. I read all I could tried the adjust this and adjust that and could never get it where it would just close. Today I thought ok lets try a different approach, I removed the striker plate and fitted that to the door then placed some masking tape on the door post closed the door and marked the tape with a thin scribe. In the process of doing this I realized that the problem was in latch mechanism on the door itself it just was not going into the closed position. A good soak with some release agent and you guest it I now have a door that shuts the way it should. So it just goes without saying check all the possible things that can and do go wrong and then check them again.
    Cheers Stuart
    Glad you got there, Stuart. I think you've earned yourself a goor ride out.
    Jonno
