The top bearing in my column is definitely gone and needs replacing so I decided to remove the column and inspect it generally while it was out of the car. Everything I read said a 30 minute job - don't you hate it when it says that and 2 hours later you're still struggling ?
Anyway, I'm stuck tying to break the joint between the bottom of the column and the intermediate shaft, it just won't budge no matter how hard I pull the column.
Any bright ideas on braking the joint appreciated.
If I can't get it loose is it difficult to replace the top steering column bearing with the column in place ?
Thanks,
John.
Thanks,
John.
