Hi, both gear box and engine plugs have a very small drip. The sump plug is new and at the right torque. Is there anything I can put on the thread to have a good seal?
Thank you,
Philippe
You are quite right. The thread in the engine sump as too the rear axle box is a tapered thread (my car is an auto). To be exact it is a ⅜ x 18 NPTF (Taper Dryseal) I have numerous arguments with suppliers who want to flog off a straight threaded sump plug, mainly because that was what they had in stock, and wanted to sell. I have managed to get a magnetic dry seal sump plug from an American source (sorry I can't find the invoice but I did find it on line
I have had a similar problem with an engine sump plug. I bought a different type from J. Paddock. It had a copper washer on it.perfect no oil leak.
Len
Hi guys, ordered one from j.paddock magnetic with washer, should be here tomorrow. The American site wasn't clear about shipping charges.
Thank you all,
Philippe
Sorry to go on about this problem but you cannot fit a straight thread plug into a taper thread drain hole. These trader will flog you numerous plugs fitted with copper washers BUT THEY ARE WRONG. Believe me I am an Engineering Technician (retired) and I do know what I am talking about. The engine sump drain on numerous Triumph cars are fitted with a tapered dryseal thread which makes an excellent seal when you fit a dryseal plug. There are threads on SOC forum some years ago that confirms this fact....Have a Look!!!
Andy. Good advice. The trouble is that the "Wrong" ones do go in to the hole, and can be tightened, even perhaps tight enough to form a seal if you are lucky, but the threads in the sump will soon get damaged, which may mean removing it to get it repaired. I wonder who would be liable for the cost of the repair?
