My car is suffering from a starboard list, front right hand side about two or so inches lower than the left, and similarly an inch or thereabouts at the rear, I have been told the usual "they all do that mate coz of the battery and fuel tank on that side" and was also told that I will need to renew all four springs to correct it.
Having had a very quick look at the manual, the rear springs seem as though they are easy, just the shocker bottom nut to remove and lower the radius arm (carefully) and the spring just falls out......my car had new rear shocks about 4 years (1600 miles) ago so nuts shouldn't be too rusty or tight hopefully.
The front are a different kettle of fish though, looks as though I will need a spring compressor, can anyone recommend one - I have a pair of hook type spring compressors, will they do?
Is it worth doing anything else at the same time? I'll obviously replace the spring insulators but is it worth changing the inserts on the front? The car has just passed it's MOT today so there shouldn't (famous last words) be anything wrong..........
Is it easy to change the inserts?
Will the ride height be ok afterwards, I've read somewhere that the car can look too high? (Mine has the Triumph V8 engine)
I'll probably go with Rimmers spring and insulator kit at £119, marginally cheaper than Paddocks but any advice would be appreciated, either concerning the job or components.
