broken stalk
    broken stalk
    Hey guys...anyone ever replaced just the headlight dip, horn stalk for another on a the indicator switch as mine is broken and hanging down?
    HI Very easy change ,take cowling off ,take a picture of old one in situ from both sides ,u will c why ,unplug from the looms ,fit new one , job done
      Sorry. you seem to have miss understood my bad description ...
      I want to keep the original body of the switch, just change out the broken stalk. The reason being that my car has the original 4 high beamset up. The new, Chinese ??, units will not work for long before they overheat and l lose main beam.. I have tried 4 Rimmer LHD ones and first off they need rewiring correctly and secondly the just don't last like the original.
        Originally posted by malc4d View Post
        The new, Chinese ??, units will not work for long before they overheat...............
        Probably a stupid question, but are you using relays or is the full current to the lights running through the switch?
        Keith
          Its the European model that was setup as 2 dip and 4 main. No relay. That's why I want to use the original switch ,the new ones are crap.
