I have just had an engine rebuild by Robsport , and a mechanic friend of relative of mine looked at it and said I ought to take the Stagweber tank off because it can over pressurize the water pump seals and blow the seals . I thought it was fitted for a very good reason and looking at it cannot see how it can do that because it goes to the rad first therefore the whole system must be the same pressure .Also I think I am right in believing that an expansion bottle is not reliable enough to send the water back into the engines thus emptying the heads and the pump of water and causing problems . I have a 20psi cap on the tank with 140 also marked on the cap so that must be the max pressure anyway. Has anyone any comments I am sure Stag Webber will have something to say .
Derek
Derek
