Hi All
Last month our Stag decided to melt its rotor arm whilst my son and I were out for a drive. I fitted a replacement and we were on our way again within a few minutes. I assumed (incorrectly) at the time that it was just a rubbish part and thought nothing more of it.
Fast forward to this morning and we were all going out for a family lunch after a drive to enjoy the glorious weather. I checked the car over and all seemed well. However, a small voice inside my head said, "look inside the dizzy cap". I removed the cap and was horrified to find the following:-
the rotor arm partially melted
the rotor arm tip worn
a deep rove in the chopper blades
plastic dust covering inside the dizzy cap
I took hold of the dizzy shaft and I discovered that I can lift it vertically by about 10mm. Basically the car was on the verge of failing again so I put it back in the garage and we used our Nissan Xtrail. To put this all into context the car has only done 130 miles since the previous rotor arm melted.
I have E-Lads Stag here for welding at the moment and I checked the dizzy on that car.It has vertical movement of about 3mm. Gresley checked his car for me and reports vertical movement of just a few thou.
At this stage I an assuming that the excess vertical movement in the dizzy driveshaft is allowing the rotor arm to come into contact with the dizzy cap and the chopper blade to touch the Illumination light sensor.
Thoughts, suggestions please.
Thanks in anticipation
Bruce
Bruce
