I have a K reg Feb '71 Stag, so mark 1, but somewhere along the line it has acquired a J type overdrive which is more a mk2 fitting.
In 15+ years ownership apart from sometimes a sluggish take up - which was resolved by topping up the gear box oil level - its never caused a problem until now.
That problem being that after driving for say 20 miles, some of which will be in overdrive, it will fall out, try and engage half a second later and repeat many times in the next few seconds before one gives up, switches it out of overdrive and marks it down as a job that needs doing.
The solenoid has been changed as that 'fix' as has the oil seal and the wiring up through the gear stick is allegedly OK.
Last evening it didn't even wait until 20 miles, as in first mile or so we had the overdrive 'hokey cokey' - its in its out.... repeat until patience decides that it aint gonna work and you switch it out.
Any thoughts anybody?
PS - I have a sleepy alternator as well. That only starts to charge after 10 minutes of driving, but it always does wake up. Is it all related?
