We've rebuilt the rear axle and put it all back together.  I'm not sure just how the alignment is set.  Basically it's off four points: the two diff studs at the back and the two bushes on the rear subframes, with those truly horrible slotted link arms to the floorpan. But all the four points have large holes in the metal work, the actual location being done really by the coned poly bushes on the diff studs sitting into the cones formed in the rear diff plate.  I'm not sure how much this controls the location, thinking that if the assembly is offered up slightly skew, the poly bushes will probably grab and stick, rather than do much to line it up because the cone angles are very shallow.  Then the skew will be set as the front end is nipped up and set by the link plates.
Certainly on the subframe end, we have a slightly larger gap between the poly bush and the bodywork at one side than the other, and the two link plates don't sit symmetrically.
Can anyone advise?
Can anyone advise?
