My brakes are spongy and need a bit of a shove to slow and stop. I have done a visual inspection and the pads are fine, a PO has fitted braided hoses, there are no leaks front or rear.
The next step is to bleed the system, the fluid in the reservoir looks a bit murky, so I am going to replace it with the purple synthetic stuff.
My question is what is the best place to start on a Stag? I normally start at the rear nearside as it will have the longest pipe run, then the rear offside, front nearside and finally the front offside.
Are there any special tips at all and does the PDWA make any difference?
If this fails then I will need to look at the master cylinder and servo, fingers crossed that it is just air in the system.
