Is this too hot?
Up until recently my Stag has been running fine. A weekend away to the Cotswolds was no problem, first decent run since the engine rebuild and she didn't miss a beat and the temperature gauge didn't move from strait up. A couple of weeks ago she let me down as the Piranha electronic ignition packed up and I had to be helped home by the AA. This was replaced by my garage as car electrics are beyond me, but on the way home I noticed the needle went higher than usual. On checking I found the neck of the overflow bottle had a tiny split. I decided to replace it with a H.T. but the gauge will not stop at upright. It goes just to be beginning of the red. I left it idling for a while but it didn't go any further. Is it possible that the gauge has decided to play up? Not sure if it helps but my cheepo IR thermometer shows temperatures of 105, 108 and 104 degrees C in between pots 2/4, 4/6 and 6/8 and 80,88 and 88 on the other side. Rad filler area was 77 and at the bottom 55. Are these temperatures acceptable? How can I be sure there is no air trapped somewhere. It says fill rad with heater on hot, my valve is stuck shut , would this cause a problem? Sorry to go on but I thought I'd give you the info I have. Thanks in advance for any help you can offer.
Is this too hot?
