I wonder if anyone can help please?
I have a TV8, with luminition ignition. There is a Lucas Super (with numbers: B.Y.S. 15P6 45336A 10 87). I have been trying to work out whether I can just replace with a standard coil off EJ Ward/Rimmers etc, or whether I need to use something more specific.
The longer story is that I was very nearly stuck out in the car with the wife. The car started to develop a few problems after a little while when we took the car out for a drive when it was really hot a few days ago. It would act like it was hesitating when trying to accelerate, and would then pick up when putting the accelerator down a bit more.
There was also a point where it wouldn't start - this seemed to turn out to be an air pipe that feeds the carbs being pushed down by the bonnet when it was closed (I noticed the engine cut out when I closed the bonnet once which was weird - and found the elbow touching). Turning the elbow slightly seemed to sort that issue out. The car however has got worse with the hesitating and pulling away from standstill was not fun. Overall the journey back was pretty stressful.
After a quick call for ideas/trying to diagnose, it seems like electrical was thought likely - and the coil seems a good place to start, hence my question...
Thanks in advance for any pointers. Any other thoughts would also be appreciated - the engine has just been rebuilt and was running perfectly before this.
Mark
Mark
