At long last the day has arrived to get the Stag on the road, but she's letting me down badly and I'm at a loss as to what her problem is
I'd started her up several weeks ago before I had to go into hospital. Started fine, ran ok, tended to overheat quickly but I found a few leaks which I cured. It wasn't running silky smooth, but didn't seem to be missing a beat - just slightly lumpy. Left it at that and went off for my op.
Got back into the garage a couple of weeks back and decided to give it the full check over and set up. Did the strobe timing (off N°2 lead!), tried to make some sense with the mixture by lifting the carb pistons, looking at Colourtune etc. Seemed to show the symptoms of being rich and the needles were well retracted into the piston. Tried turning out the needles and the Colourtune lost its bright yellow colour. All seemed well so I left the engine and continued to finish off other bits and pieces like windscreen washers etc.
Went to start it today and the bu$$er wouldn't start. After several attempts it did actually turn over but was really lumpy and a couple of times the carbs coughed at me and the engine died. It responded to the accelerator when it actually agreed to fire up, but after 15 seconds or so at higher revs the engine just died.
The only thing which was different to when I fired it up originally was that I'd put oil in the dashpots. I unscrewed the dampers and she really liked that! Started running ok and seemed to even start to get smooth. I put the lumpiness down to oil or whatever in the cylinders from the rebuild etc., and, whilst it was running ok, I got the air filter etc. back into place and screwed in the dashpot dampers again. It seemed more willing to start and it didn't die on me. Still quite lumpy though.
I just decided to drive it a few hundred yards around the block and it was not so good. Quite lumpy, pulled away ok, didn't stall, but sounded somehow like a cylinder or two was missing. Only evened out at higher revs. To cap it all, temperature soared up and even the warning buzzer I'd installed went off (nice to know it works!)
I'm lost - help!
maybe I shouldn't have believed the Colourtune and I've weakened the mixture far too much?
I keep having daytime nightmares about pistons, cylinders etc. and guess I might have to do a compression check, but I can't see how that would have occurred after it having fired up so well the very first time.
Cheers for any pointers!
Drew
I'm lost - help!
Drew
