Having done very little with the Stag for a couple of months and I a considering putting it on SORN in October as we are going away for a couple of weeks I am considering starting the winter overhaul early.
One issue that I had were noisy tappets on the left bank which I reset some months ago, which quietened the problem, but, whist doing that I found some worn valve guides, mainly on the left hand head where I found a considerable build up of carbonated oil in the cam followers. The right hand head by comparison was "clean" leading me to believe that the right hand head had been off whilst the left hand one hadn't.
So today I carried our a compression test which produced the following results :-
Now the question is, do remove just the left hand head OR do I remove both heads ? I am aware that number 6 cylinder is the Beelzebub of the engine (does anyone know why) and this appears to be the worst cylinder, No. has had a insert fitted to the plug threads after it blew a plug out and a few other threads are "iffy"
The vehicle has always had a "Harshness" to it which could be the imbalance of the engine banks, or not.
There is no overheating, no unusual oil consumption, no oil burning, it has return 27 m.p.g. on a fault free 1700 mile trip to France ,there is some coolant that appears in the V after a run which I think is the manifold gasket.
Your comments and suggestions would be welcome.
Thanks in advance
Nigel
| Right Hand Head | Cylinder | |
| 1 | 180 | |
| 3 | 180 | |
| 5 | 180 | |
| 7 | 175 | |
| Left Hand Head | ||
| 2 | 165 | |
| 4 | 175 | |
| 6 | 135 | |
| 8 | 180 |
Thanks in advance
Nigel
