I am a new Stag owner and wondering what colour antifreeze I should use ? My Haynes manual says any to BS3151 but that seems to be an old reference number ? Confused !!
what colour antifreeze ?
Surely it depends on what is currently in the system unless the system is going to be drained, thoroughly flushed, then refilled. My preference these days is for OAT or red (note its not entirely wise to go on colour alone to identify the antifreeze type). Have been using OAT for over 10 years in all my cars - classic and modern, never had a problem. Peter at LDParts also rdcomends it.
RogerNow Stagless but have numerous car projects
Johnboyw
Originally posted by marshman View PostSurely it depends on what is currently in the system unless the system is going to be drained, thoroughly flushed, then refilled. My preference these days is for OAT or red (note its not entirely wise to go on colour alone to identify the antifreeze type). Have been using OAT for over 10 years in all my cars - classic and modern, never had a problem. Peter at LDParts also rdcomends it.
Originally posted by Johnboyw View PostJust acquired the car and think that there's just water present at the moment. Car has been off the road for six years and the guy that sold it to me no longer wants to know!! I will drain some off and check. Thanks for your advice.
The stag should have a coolant mixture with corrosion inhibitors all year round. Various opinions on here as to what is best but seems that 33% blue to water is most common recommendation. However please note that water should be de-Ionised s sold at Halfords etc. or elsewhere forbatery top up, steam irons again etc. Alternatively filter water from a rain butt and use this.
HTH
H
Originally posted by Arbman Al View PostI heard recently on another car forum that oat antifreeze attacks soldered joints like in heater matrixes.
I have also changed several cars over from the blue/green to OAT and all I have ever done is to make sure they have been thoroughly flushed through with water. I have never used a chemical flush I would have thought that would be used more to clean the water ways than to mitigate any possible effects of changing coolant types.
Originally posted by marshman View PostI have heard this as well along with comments/statements that OAT attacks some older types of gasket material. However, as I said I have been using it for over 10 years in various cars, some dating back to the 1950s which have loads of copper, solder and brass, with no ill effects, and yes I have drained the systems down to work on some of the cars and looked at "vulnerable" components (radiator and heater) and everything looked clean and un-corroded. Another thing is that the OAT (red) coolant always comes out looking as clean and clear as when it went in - even after 5 years.
Cheers...Al.
