Is this a Stag panel?
    What punishment would I get then My offer still stands, £500 for the lot with free P&P
    [ATTACH=CONFIG]38979[/ATTACH]
    They are a bit scruffy. I'd want some mint looking ones for that sort of money.
      And fitted!
        Originally posted by dasadrew View Post
        Could you deliver the package to Mars?
        So tempted
          So tempted
          surely you don't mean I'd have to be in when it arrived sir!
            Cheap as Chips Ian. Would the chrome surrounds be another £500
              So, going back to my post, is anyone interested in the panel before it goes on eBay?
                Can't believe SOCTFL don't want it
                  i have the same panel,to fit the whole panel is a really a lot of work,generally you only need repair sections made where the drainage tube go
                    Even using this panel as a template for any future body shell requirements.
                      Never say never but I'm not sure this is a part we could easily reproduce Andrew. I expect that the tooling would be eye wateringly expensive as we would have to use steel draw tooling (and probably more than one tool) as there is no longer a rubber press that could produce a panel of this size. Rubber press panels are usually a lot cheaper to produce, for example the steel draw tooling for a panel we were investigating (until we found that rubber presses were not viable) was 2-3 times more expensive than the rubber press equivalent.
                      The other issue is the unknown provenance of the panel, I don't know if SOC spares was the only producer of this panel in years gone by but an original seat pan from a car would be a better template for a new panel. As it happens, I have one in my garage taken from a good shell.
                      Thanks for bringing it up though and I hope my post helps?
                      Paul
                        Thanks Paul. I'll advertise it on eBay for him knowing at least it's been offered here first.
                        Andrew
