Water pump delete plug
    I negotiated a Davis Craig pump Christmas present!
    Anyone know where I can get one of these water pump plugs.?
    Dolomite club? but I cannot see where ..
    I see somewhere about plugging it with Welche plugs, anyone done that??
    Ahahhh "BUNG" was the keyword.. I have lived in the USA too long!
    But 40quid.. ouch!
      But 40quid.. ouch!
      Better get it quick, Terry, before our exchange rate improves
      You should be immune from the VAT!
        Terry pull out your old pump and cage use cage to get a machine shop to make you one up
        Cheers Glenn
          Cheers Glenn
          Or do like I did and get a plug turned to fit the inside of the brass cage. I made one myself out of a lump of alloy and used silicon sealant to hold it in place. That way you don't need to get O ring grooves machined in the outside of the bung which makes it simpler and cheaper.
            Yup
            I eventually found that post and that's the way I will go, Thanks
            Terry
              Yup
              Terry
              Terry,
              When I needed one,they weren't in stock anywhere, so I used the cage to make my own. Looks like it's catching on!
              Stag_water_pump_2.JPGStag_water_pump_3.JPGStag_water_pump_4.JPGStag_water_pump_Bung.jpg
                Originally posted by Stagsongas View Post
                Terry,
                [ATTACH=CONFIG]39055[/ATTACH][ATTACH=CONFIG]39056[/ATTACH][ATTACH=CONFIG]39057[/ATTACH][ATTACH=CONFIG]39058[/ATTACH]
                I actually copied your idea Steve, and I will do the same again when I build my next engine.
                  I'm pleased it was useful to you Neil, I value your posts and forum input too.
                    I have already punched a few thousand into the British economy.. I'm doing my bit!
                      Gents,
                      I am looking to use a cage (when I find someone who has a spare....anyone have one please?) as a bung and machine up an internal bung to fit inside as I have seen on previous posts such as this. However I am a little unsure how those that have done this have stopped the engine oil getting past the joint between the bung OD and the ID of the cage, and up and out through the water flinger holes. I ask as this as the bung descriptions mention making it a sliding fit in the cage and on occasion using some form of bonding agent. Is it the bonding agent making the seal and stopping the transfer of oil in the bung - cage joint, or am I not quite understanding this approach please?
                      Thanks as always
                      Mark
                        In the end I just plugged it with freeze plugs.. you need 2, one for the oil and a slightly bigger one for the water.
