Removing a manual gearbox
    On Saturday, after months of deliberation and discussion, my friend Steve and I decided to bite the bullet and remove the manual gearbox from his Stag so that it can be reconditioned. For the last 12 months there has been a very loud howling noise from his gearbox which gets worse with speed. There was also a rattle at idle which was diagnosed as the clutch release bearing.
    We both have office jobs and fall into the enthusiastic amateur category of Stag owner. We started at 9.00am on Saturday and with plenty of teabreaks and head scratching had the gearbox out at 7.00pm (that’s about 16 man hours – we won’t be giving up the day jobs anytime soon!). The following points may help others who are thinking about doing this job:
    1. The manual recommends draining the coolant and removing the heater hoses and then removing both exhaust downpipes. We had also been advised to remove the distributor. However we just removed the coil and took the distributer cap off which gave sufficient access at the top of the engine. There was sufficient flex in the heater hoses which meant that we could work around them without draining the coolant. We removed the passenger side downpipe and managed to break 1 stud in the process. The driver’s side exhaust manifold studs were locked solid and so we decided to leave well alone.
    2. There are 18 bellhousing bolts of which about 10 need to be removed in the engine bay. There is no access for sockets. We used a selection of thin ½” and 13mm spanners but access was still very difficult. The best tool we used was a 13mm ratchet spanner – I definitely recommend getting one of these. It took both of us to remove each bolt – one to hold a spanner on the bolt to stop it moving and the other to undo the nut.
    3. Removing the gearstick is well documented in the manual and was straightforward.
    4. We then raised the car as high as possible onto the ramps. We removed all the clamps holding the centre sections of the exhausts.We tried separating the exhaust at the balancing pipe but even with a scissor jack it wouldn’t budge.
    5. We then painted a reference point on both ends of the propshaft and removed the bolts – again needing 2 of us to stop the bolt heads moving. Those at the diff end were very tight and fiddly to get at. With a bit of levering on the exhausts with wood blocks we were able to draw the propshaft out from the diff end.
    6. We drained the gearbox oil and found a 1 inch high stack of iron fillings on the magnetic drain plug – perhaps an indication of the poor health of the gearbox.
    7. Steve had bought a Dirty Pro gearbox cradle for £30 which was mounted on a trolley jack and then attached to the gearbox. We then removed the remaining bellhousing bolts and the rear bracket – this was also very fiddly.
    8. We then tried separating the gearbox from the engine but it wouldn’t budge. Eventually we forced a screwdriver between engine and gearbox followed by further levering with larger screwdrivers, a crowbar and then blocks of wood. We then reached the end of travel in the transmission tunnel but weren’t sure whether the gearbox main shaft had separated from the engine. We tentatively lowered the rear end of the gearbox down and then moved a few inches further backwards and then it was obviously clear of the clutch housing. Having the driver’s side downpipe still in place wasn’t a problem when manoeuvring the gearbox.
    The gearbox has now gone to be reconditioned and should be back in about 10 days. For those that have done this job before, do you have any hints or tips which might help us put it all back together?
    Chris
    Get someone else to do it
    If you haven't got one you need a clutch alignment tool.
    If the garage doing the box doesn't replace the cross shaft pin get a stronger one from LD parts or any other supplier and fit that.
    While the box is out it might be worth checking or replacing the rear crank shaft seal with a double lipped one.
    replace the clutch assemble?
    just take your time re fitting and don't force the box first motion shaft through the clutch plates, make sure it's all lined up, use some grease on the first motion shaft too.
      Getting the clutch plate aligned (assuming you'll be replacing the clutch at the same time) is I found a tricky job but an imperative one.
      If you can find a spare input shaft that you can use as an aligning tool so much the better but otherwise a quality aligning tool will do the job.
      I found the engine can be dropped so that the sump rests on the front cross member but make sure you move the brake pipe that runs across the back of the member to prevent it from getting crushed.
      Also, (unlike what I did and learned expensively) make sure there are 3 locating dowels in the flywheel for the clutch cover as if any are missing you will, after about 200 miles get an untraceable and annoying vibration because the clutch cover has started to rattle!
      Lastly, make sure the larger locating bolts in the bell housing are in the right place as if they are not you will have problems with clutch alignment. LD parts sell I believe these bolts to make the job easier.
      Apart from that, pretty simple to get back in - it's just dammed heavy!
        whilst it's out I would (did) replace every clutch part and the oil seal and as above take it nice and slow when reassembling ,good luck and use plenty of Savlon
          Ah yes forgot about those alignemnt bolts. I bought them from LD parts but they dint fit anywhere on my box? If I still have them you can have them FOC if you want. Can't promise I still have them though!
            They do fit, you just have to remove the burrs on the outer of each face, they worked really well for me anyway!
            And there was only one of me for the whole saga. 3 times removal and refit in the end ('cos of clutch issues, and then a heavy duty clutch and release bearing from Paddocks that Russ swears by, nice bit of kit that has worked really well for the last 2 summers.
            Andy
            Andy
            1973 Stag (called Stanley), White, ongoing work in progress.
              There are long bolts which fit in the lower area - as I am guiding the box back on, I use these where short bolts should be, to help get it roughly in the right place. Don't use these as pullers, just as alignment guides.
              Also, before lifting the box in, put it in gear (4th), so that you can turn the input shaft by turning the output flange. That will help 'fiddle' the input shaft through the clutch plate.
              By the way, with a good set of extension bars and UJs, you can get to most bolts with sockets, from the back, around the bell housing. Often need to use 3/8th drive sockets and bars, rather than 1/2".
              '72 Manual O/d Saffron Yellow
                I've never used an alignment tool, these tend to be a bit loose, and if they're not spot on they're a waste of time. I just make sure the outer edge of the clutch plate is consistent all the way round with the face of the driven plate, you should be able to clearly see them at least in 3 areas, before the plate is finally tightened up. Just as quick and more accurate.
                  I always used a spare gearbox input shaft as an alignment tool.
                  Of course, these days, I have to fiddle those four bl**dy bolts into the torque converter!
                    ... replacing the rear crank shaft seal with a double lipped one.
                    Any idea where I can get one of these? I've had a look at the one offered by LD parts but can't convince myself that it isn't a single one looking at the picture.
                    James
                      James
                      i don't know James, Stagmuffin kindly gave me mine. Well worth doing though as I had fitted a single lip and it still leaked so "simply" had to remove the box again"
                        Andy
                        Andy
                        They didn't fit mine, I even emailed Peter and he recommended knocking them in, which I didn't want to do. But I don't seem to have any clutch issues so I guess I may have been lucky?
                          Great,Glad to hear.
                          Andy
                            Thanks for all the advice. The gearbox is now back from being reconditioned and we are going to refit it this weekend. The clutch has been replaced even though the old one looked hardly worn. The gearbox specialist recommended refilling the gearbox with a mineral 20w-50 engine oil rather than 80w90 gear oil. Does anybody have any thoughts on whether this is the right thing to do?
                            Thanks, Chris
                              I use EP 90 gear oil. My old MGB GT with overdrive ran on 20/50 oil. So maybe either can be used?
