I'm sorting out the last few challengers on my EFI project to get it finished, only been 10 years since I started!
Cold start, is an idle control valve or IAC really necessary?
As I'm using motorbike Suzuki GSXR 600 K1 throttle bodies, I don't have an easy facility to add one.
I do have little vacuum ports on each of the 8 throttle bodies, but they are really small (maybe half a mm diameter each) and I don't think would introduce sufficient air. Don't really want to be adding 8 additional air inlet connections to each inlet runner.
What I do have however is the facility for a manual 'choke' that was used on the bike. All this does is manually open the butterflies slightly to introduce more air and increase the idle speed. So not a 'choke' in the true sense, just a little extra throttle.
I assume Megasquirt automatically enriches the fuel/ignition advance on coolant temperature anyway, so this manual method to increase idle speed at the same time might work, or maybe isn't necessary anyway?
Few other curious questions really:
MAP or throttle position?
I'll be using throttle position, apparently this is the way to go with multiple throttle bodies, and I already have two available to use on each bank, but only need the signal from one.
Fuel pressure regulator.
Some use the vacuum signal to vary the fuel pressure, some don't, keeping the fuel pressure fixed at the same pressure no matter what the inlet manifold vacuum level?
I've spent most of the weekend looking, playing, and looking again on how I am to control all 8 throttle bodies in perfect synchronisation.
With me spacing out the bodies wider than when fitted to the bike, I'd lost some of the original synchronisation along each bank of 4, however I've now sorted that one out with careful modification, fabrication, and extension to original interconnecting levers.
The challenge is now applying the single throttle cable from the pedal, to moving both banks together. I think I have found the answer, but don't like the price!
I can't believe there isn't anyone in the northern hemisphere that sells the same thing!
Jenvey do one, at the same price, but not a patch technically on this Aussie one!
