Seats
    Seats
    Hi,
    Does anyone have a photo of the underside of a seat where I can see how the diaphragm is attached to the seat with the hooks? I would like to replace the diaphragms on my seats, because the PO only used tarpaulins. And these seem to be to soft.
    Gerd
    1976 TV8 Manual O/D in pimento red
    1986 BMW R80RT
    Hi Neil,
    thank you for the helpful links.
    It looks like the diaphragm should be clipped on as the basis for the build up of the entire seat.
    But I only want to exchange the diaphragms. Will that work?
    Gerd
    1986 BMW R80RT
      Yes you can change the diaphragms with out taking the cover off
        Thank you, Dave. So I'll give it a go.
        Gerd
        1986 BMW R80RT
          Two more pictures Gerd. Before and after the new diaphragm.
          Viel Erfolg
          Klaus
            Viel Erfolg
            Klaus
            [ATTACH=CONFIG]39271[/ATTACH][ATTACH=CONFIG]39272[/ATTACH]
            Thank you, Klaus. Obviously, it's an improvement.
            Gerd
            1986 BMW R80RT
              As far as l remember, you will need new hooks with the new diaphragm as the old ones are to short.
                Gerd
                Gerd
                there are two types of diaphragms available,a thin one or thick one,the thick one is the best type to fit,but is harder to fit as its stronger ,i know Jim from South East Trimmers sells the thick type,i have used them myself
                  on a similar subject which way to I turn the seat winder to lower the seat? clockwise or anticlockwise as seen looking at the handle? (in other words an accelerators eye viewpoint)
                  thanks
                    thanks
                    Can't check this at the moment, but I think the difference between "high" and "low" is very small and not noticeable.
                    1986 BMW R80RT
                      Might explain it then, how many turns should I get? Mines about 3 but the seat seems a little higher than I remember, mind you it's got freshly retrimmed seats too.
                        Gerd, if you have not already finished your diaphragm project:
                        I found it helpful to use long tie strips through the holes in the rubber in order to pull the diaphragm close enough to the frame and then fix the metal hooks.
                        Klaus
                          I used a large old screwdriver with a vee saw cut in it to push the hooks towards the frame (AWAY from me as I did not want to stab myself)
                          I used very strong cord from the diaphragm tied to the up/down mechanism to wind it towards the frame first
                          Still a strong-arm job Good Luck & Enjoy
                          Makes the seat feel great when done
                          Phil, Mk 2, 1974 Emerald Green, Auto, (HT & Kenlowe Fan)
                            I have turned mine both ways and am sure that any change is psychosomatic. I was toying with using a dial gauge to measure the movement!
                              Klaus
                              That sounds like a good idea. Today I started with the passenger seat. And it was hard enough to get the tarpaulin off. It looks like I have to take the seat runners off. Will see how it works.
                              1986 BMW R80RT
