When you have an issue with your steering, either too stiff/loose, not responsive, leaks or notchy. You resolve one issue only to highlight another.
Leaks and lack of power steering=replace all the seals in the steering rack even the one your not supposed to and tighten up the side float.
Highlighted
Notchy steering= replace steering UJ.
Highlighted
Play in steering= replace/place outer bush/grommets.
Highlighted
Still not 100%=replace lower bushes.
Highlighted
Play in upper steering= replace Steering Column Inner bush only find out you need two and there's a better way of securing the top bush rather than using the serrated washer.
That will hopefully be the end of it, should be tight like a tiger but not too tight. There again there not a lot more to replace.
Highlighted
Highlighted
Highlighted
Highlighted
