shocking price for seals.
    Hardtop 1/4 light seals £244 of our English pounds.
    joel.
    Not by the time you club them, clean them, then cure them, full dark fat ones are even more expensive.
      Joel.
      Doesn't that make the SOCTFL sponsored ones for the door lights remarkable value!!!!
        Originally posted by Lingen View Post
        Joel.
        Yup, From LD Part, they are just £41.36 incVAT for a pair, great value!!
        1973 Stag (called Stanley), White, ongoing work in progress.
          I know there wont be a big demand for Hardtop seals but even so, that price is bloody rediculous.
          pardon the pun but there is a WINDOW of opportunity there for someone to make these.
            Buy a walrus instead. More blubber for your dollar!
              Whose charging £244? I can't see why they should be so expensive; it is only a furflex seal like our door seals after all. When I restored my hard top back in 2002 I took some of the old seal to a scrapyard and compared it to seals on scrapped cars. ISTR I used the door seal from a Jaguar XJS as it was a close match. The Stag hard top seal has metal connectors in the corners, but these can be re-used or even left out as they aren't essential.
                Buy a length of fur flex and make your own? That's what I plan to do
                  RIMMERS robsport etc. part No813861-71 £244 For the pair. they do look like they are moulded to shape with lips and grooves, very similar to the door 1/4 light glass seals. I was just gobsmacked by the price. I will be using something else and jag has been mentioned to me before so thanks for the tip.
                  joel.
                    Joel.
                    hi Mike yes most definitely, I don't suppose there is a demand for the hardtop seals though.
                    joel.
                      it will be something I look into. cheers Joel.
