Well its fully wrapped now all the chrome on just a few things to sort out, well loads if I'm being honest.
70 % of its all done.
It moved on it own for the first time yesterday. There was a fuel problem so it didn't run like i hoped. The the clutch line let go again, so it might be gearbox off again in the New Year.
Soon as the clutch went so did the fuel problem and the engine ran sweet. The dump valve swooshed so it getting boost as well. Still waiting for the new wheels and hubs to turn up then the drive shafts can be made/fitted. Might have mod the wheel arches or move the trailing arms to get the tyre clearance. More fun.
Originally posted by bullstarz View PostWell its fully wrapped now all the chrome on just a few things to sort out, well loads if I'm being honest.
[ATTACH=CONFIG]39451[/ATTACH]
Joakim
Originally posted by jagorstag View PostThat's one mean looking Stag! I think you'll have to play Judas Priest's 'A Touch Of Evil' on the stereo when out cruising....
Joakimsigpic Stag Haulage, Flookburgh
Long play list ready to go, AC-DC Shoot to thrill and thunderstruck. The stereo is on the to do list. Was going to go for a Sony double din unit but wasn't to sure about it getting nicked being a convertible. So ill just go for a hidden Wi-Fi or blue tooth receiver linked up to the crossover/amps/speakers. I just have to find all the stuff as its been out of the car for some time.
Originally posted by bullstarz View PostIt moved on it own for the first time yesterday. There was a fuel problem so it didn't run like i hoped. The the clutch line let go again, so it might be gearbox off again in the New Year.
Cheers Glenn
The one wheel sticking out more than the other problem is not unusual. I usually end up welding up the trailing arm bracket holes and then re drill them closer to the edge of the bracket to pull everything back into alignment.
Have done the same thing on my TR due to wider rear wheels. The original splined shafts can take the variation in length without a problem.
NeilNeil
Originally posted by flying farmer View PostThe one wheel sticking out more than the other problem is not unusual. I usually end up welding up the trailing arm bracket holes and then re drill them closer to the edge of the bracket to pull everything back into alignment.
once all that is done it can go within a sniffing distance of a rolling road.
Mine like others has a difference from side to side.
Actually it has annoyed me for 30 years!!Mike.
